We use Monaco to configure our SaaS Dynatrace environments.
However, some parameters do not seem to be configurable with Monaco:
- Configure “Web request Naming” in services
- Set the Key User Action in FrontEnd
Do you know if there is a way to integrate them into Monaco?
Or if this is soon planned?(Modifié)Restaurer la traduction d’origine
You can find all supported APIs here.
If your API is not there, you can raise a product idea.
Best regards
Just 2c to add to @AntonPineiro’s answer - both of the settings you are looking for are not possible using API, thus not supported by configuration as code. (this is valid for current Dynatrace version 1.278)
Thanks for the information.
Do you know if there are plans to do this soon?
