I am deploying some log monitoring rules (processing, log events) and no problem using DQL matchers. But if I try syntax without DQL, it complains during deploy.
Do you know if we must use DQL syntax? We would like to deploy this configurations in some non Grail enabled tenants.
As an example:
Green line is working fine using DQL. But red line (logs classic) does not work. And that configuration was created in the UI without problems and it is literally what you get with “monaco download”.
Were you in this situation before? Have you tried to deploy log monitoring confiurations, with Monaco, without DQL?
Best regards
