Monitor PeopleSoft logs with OneAgent
I want to monitor my PeopleSoft logs but I can’t find documentation for it, I’m not sure if I need the Oracle extension or if a OneAgent can monitor those?
Thank you
If you have OneAgent installed, you can monitor logs.
You have a logs section where you can see logs autodiscovered by OneAgent. Appears your log there?
Best regards
Hi Ana pau,
You should be able to monitor PeopleSoft logs in Dynatrace using OneAgent without requiring the Oracle extension. We currently do not have a guide to do it. I suggest you install the OneAgent. If autodiscovery does not detect the logs, you can configure custom log sources to specify the location and format of PeopleSoft logs. If you have access to PeopleSoft Health Center, you can view the log files there.
Check these two links that might give you more details about how to check the log files and format.
