It seems to me that for hosts the entity selector entityName:
is the same as the displayName?
KR Henk
Hi Henk, my thinking is that the displayName should be the same as the entityName. This would be the name you see displayed for your hosts on the hosts app. Also referencing this post Automate enterprise operations using the monitored entities API v2.
Hope this can help!
Hi Keegan,
Very good, lets assume a very little technical debt and good to know!
Thanks Henk
