Summary: This thread explains which Dynatrace API endpoints return displayName together with entityId. It outlines available fields, parameter requirements, and typical patterns for entity queries.
While getting metrics using Metrics API - GET metric data points — Dynatrace Docs api, getting the entity_id in the dimension field.
Is there a way to get the entity display name or display value along with the entity_id as part of the metric get data points api?
