Monitoring Broker status and Execution Group status on IIBM
Can someone answer if Dynatrace OneAgent or an extension is able to monitor Broker status and Execution group status on IIB (IBM Integration Bus), 10.0.0.23 version?
Many thanks,
Srikanth
@ssamraj were you able to get any information on this?
Thanks for checking.. Not at this point of time..
@ssamraj do you still need help with your case?
Or have you already found a solution? If yes, feel free to share. Other Community members would be happy to know the answer.
I am also interested in this question.
Thanks for checking.. I’m unable to find anything..
@ssamraj the Dynatrace IIB/ACE module detects all processes that start with the bip prefix, for example  bipbroker, biphttplistener, bipservice,… and monitors their availability.
For Execution Groups (aka. Integration Server), we detect the DataflowEngine process if an IIB node is present, or the IntegrationServerif no IIB node is present.
Thanks much..
