Monitoring IBM API Connect
Hi all,
Does anybody have experience in API Connect monitoring with Dynatrace?, or know if its possible?. I can´t find any official reference.
Thanks in advance
Hi guys,
Any update here? we see more and more sites that uses IBM API Connect and ask for monitoring with dynatrace.
Yos
I think IBM has to start working with dynatrace in the same way that AWS is about preparing solution for this. For now still there is no possibility for such monitoring as I know.
Hi @sebastian k.
Question is there an intention, from dynatrace side, to build active gate plugin , as built for IBM DataPower for example
Yos
Also interested in the monitoring of API Connect.
I noticed in the following article: Dynatrace Blog | Dynatrace news that the next steps is the support for IBM Application Connect 11. What does this entail? When will this be available?
Barry
AG plugin will provide you only metrics, not transactions. This is why I’ve said what I’ve said :slightly_smiling_face:
Metrics are better than nothings … :wink:
hello! i’m interested about this new feature, When we have news?
My customer will be use AWS + apiConnect (on site), for his news products
Carlos.
We have tried IBM API Connect analytics api to collect the all API calls and specific metrics of API’s like errors, response time, throughput, etc  using Activegate extension.
Hi @Santosh
Can you please elaborate a bit on your testing with IBM API Connect analytics API?
What was the result of your try?
Thanks in advance for any information on this
Yos
Hi @Yos,
We tried the below event analytics api to collect the API details like response time, status code, api name,  URI path, Productname, HTTP method etc.
https://<apic analytics server>/v1/orgs/api/environments/xxxx/events
Then we have created the below metrics in dynatrace using activate extension with dimensions API name, Http method, status code.
TimeToServeRequest
StatusCodeCount
NumberOfApiCalls
FailureRate
FailureCodeCount
Every minute this extension execute rest call to APIC analytics servers and collect these metrics details. So we create the dashboard as per requirement to analyze respective api calls and generate the custom events.
Thanks @Santosh for sharing the information!
Yos
Hi @Santosh
have you some documentation that i can read to create this?
thanks!
Hey Santosh,
Can you provide more details about this solution?
Also looking for ways to monitor IBM API connect. Any updates on official Dynatrace support?
If anyone succesfully monitor IBM API Connect in any way, please reach out
Dear All,
I would like to inquire if there are any updates regarding this requirement.
Babar Qayyum
