Tracing for Rabbit MQ works already. Since your services are .Net based make sure you enable the support for it in your Oneagent features: Settings → Preferences → Oneagent features → switch on ".NET messaging RabbitMQ SensorV2"
Yes, we have enabled RMQ sensor and we are seeing it reflected in the distributed traces. My question however is, since my custom metric is based on the two different services start time, how to get/extract start-time for each of services.
Ah now I got it right.
I fear your only way to get to this data is via a DQL query on spans (traces on grail).
The other idea how this could be achieved is via BizEvents, but since Dynatrace still doesn’t support the creation of BizEvents from code-level sensors (only from incoming http calls) you would have to implement the ingestion of a BizEvent yourself in the producer/consumer …
