RabbitMQ-MT-FAULT-MESSAGE in Dynatrace
Hello! I welcome everyone!
The screenshot is provided on the RabbitMQ interface. I would like to display the MT-FAULT-MESSAGE in Dynatrace. How can this be done?
I appreciate your assistance in advance.
Have you tried using Request Attributes to capture the header information?
Radek
Hi @jakab3t_mav_szk, did Radek’s reply help you? Or were you able to solve your issue some other way?
Hi!
I already knew that…
If it had been that simple, I wouldn’t have asked.
We have an application server and of course we have OneAgent on it and of course we have done the configuration in DynaTrace.
I want to display the MT-Fault-Message in DynaTrace.
The header contains MT-Fault-Message.
However, if I include it as a request attribute, it does not display.
