Monitoring of the shared resources between two environments
Dear All,
Is it possible to monitor the shared resources between two Dynatrace Cluster Environments (UAT & SIT), for example, OpenShift and Mainframe?
Both shared resources monitoring by the Dynatrace UAT environment.
  • How to have the visibility of both shared resources in the SIT environment as well?
  • Will the cross-transaction monitoring work in this scenario?
  • What could be the best practices in this situation?
Note: The alternative is to make a Management Zone inside the UAT environment, for example, SIT, and include all the entities part of the SIT environment (Is this the right approach?).
Babar
