I know this is a fairly generic question, but I wanted to check if anyone here has integrated Dynatrace for monitoring Genesys CCaaS or any other CCaaS platform.
I’m trying to understand, from an observability/SRE perspective, what telemetry and metrics are typically monitored across CCaaS components such as:
- IVR
- Routing
- Integrations/APIs
- Agent client/desktop
- Dialer services
At the moment, I don’t have the full architecture details, so I’m mainly looking for general guidance or real-world experience around monitoring strategy and integration approaches.
I’m also curious about how people usually integrate Dynatrace in these environments:
- Using APIs and custom extensions
- Synthetic/RUM monitoring
- OneAgent deployment (although from what I found online, installing OneAgent directly on Genesys Cloud components may not be possible since it’s SaaS)
If anyone has experience with this setup, I’d really appreciate any insights, architecture examples, best practices, documentation, or videos that explain a similar monitoring strategy.
Thanks in advance!
Hi @explore_DT
Honestly, I haven’t faced these scenarios but this looks very interesting case. Since Genesys Cloud is SaaS, you can’t install OneAgent on their infrastructure — so the monitoring strategy is “outside-in.”
If I were in your place, here’s how I’d approach it:
1. Integration/API Layer (Best visibility) — Deploy OneAgent Full-Stack on your middleware/integration services that call Genesys APIs. This gives you distributed tracing up to the Genesys boundary.
2. Custom Metrics Ingestion — Build an Extension Framework 2.0 extension (or a lightweight script) that polls Genesys Cloud Analytics APIs and pushes metrics (queue times, IVR completion rates, SLA %, dialer stats) into Dynatrace via Metrics API v2. This gets you Davis AI alerting on CCaaS KPIs.
3. Digital Experience — RUM on custom agent desktops (if web-based) + Synthetic monitors for critical API endpoints and agent workflows.
4. Log Ingestion — Genesys event webhooks → Dynatrace Log Monitoring for error detection and correlation.
What you can’t do: Deep monitoring inside Genesys platform internals (no OneAgent, no PurePath inside their services).
What works well: Monitoring your integration layer (Full-Stack), ingesting Genesys metrics via APIs/extensions, Synthetic + RUM for digital experience, and log ingestion from event streams.
Hopefully this gives a solid starting point.Thanks,Sujit
