I wanted to check and confirm what are the different way we can monitoring the application in Dynatrace? i am aware that the one is installaing OneAgent, other one is ActiveGate. another type?
@Selvam_Sekar It comes down to the type of application and the monitoring use case you are trying to solve.
You can use Synthetic Monitoring , Log Monitoring, ingesting LMT using OpenTelemetry , Out of the box and custom extensions in Dynatrace, API’s and many other ways…
Your question is very broad, but I’ll try to keep it short.
As @p_devulapalli it’s depends of application, data source and use case.
The main options are:
OneAgent (host / VM / bare metal / container). Primary way to get full-stack APM, service tracing, deep process visibility, etc.
Can run in different monitoring modes: Full-stack, Infrastructure, or Discovery (lightweight).
2. ActiveGate - it’s a gateway component used for routing/secure connectivity and for specific modules/integrations (cloud, remote monitoring, etc.). Dynatrace has Environment ActiveGate and (in Managed) Cluster ActiveGate
3. Synthetic Monitoring
- Public locations (Dynatrace-managed global network) for external checks.
Public Synthetic locations in Classic — Dynatrace Docs - Private locations (your network) require Synthetic-enabled ActiveGate and it must be a clean, dedicated install
Create a private Synthetic location in Classic — Dynatrace Docs
4. Real User Monitoring (RUM) for web it’s monitoring by inserting the RUM JavaScript tag (manual insertion / tag)
Set up agentless monitoring in RUM Classic — Dynatrace Docs
5. Mobile app monitoring. Instrument iOS/Android apps with Dynatrace OneAgent for Mobile / OneAgent SDK
6. OpenTelemetry ingestion (traces/metrics/logs) - Dynatrace OTLP API endpoints — Dynatrace Docs
7. Extensions (out-of-the-box + custom) - Extensions — Dynatrace Docs
8. APIs for custom ingest
- Push custom metrics via Metrics v2 ingest Metrics API - POST ingest data points — Dynatrace Docs
- Push logs via Log Monitoring API v2 ingest (or OTLP logs) Log ingestion via API — Dynatrace Docs
Last but not least: Kubernetes monitoring.
And this is another topic, because here u have other posibilities:
1) Kubernetes platform monitoring (cluster/platform only)
2) Kubernetes platform monitoring + Application observability
3) Kubernetes platform monitoring + Full-stack (cloud-native full-stack)
4) Classic full-stack (legacy mode)
Wow — that was quite exhaustive… this should totally be an official Dynatrace cheat sheet ![]()
