MountVolume Error while migrating from ClassicFullstack to CloudNativeFullStack monitoring Mode Dynatrace in Kubernetes/Openshift cluster
Symptoms
Application pods cannot start; facing MountVolume error after migrating from ClassicFullstack(CFS) to Cloudnative(CNF).
Error event
MountVolume.MountDevice failed for volume "pvc-xxxxxxxxxxxxxx" : rpc error: code = Internal desc = failed to get disk format of disk /dev/rbd0: blkid returns invalid output: ERROR: ld.so: object '/opt/dynatrace/oneagent/agent/bin/current/linux-x86-64/liboneagentproc.so' from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored. DEVNAME=/dev/rbd0 TYPE=ext4
  • Error persists even after removing Dynatrace components (Namespace, DynaKube, Operator, Webhook, OneAgent and ActiveGate) and restarting application pods.
  • /etc/ld.so.preload is either empty or does not exist.
  • The node still has the old reference of /opt/dynatrace/oneagent/agent/ CFS, which should be changed to /opt/dynatrace/oneagent-pass/ in CNF.
 Resolution
  • Restart the Nodes where the application pods were deployed.
  • Move forward with a clean CloudNativeFullStack Operator installation.
Note
If you are running Kubernetes clusters utilizing a CRI-O container runtime and running OneAgent version 279 or earlier, there is an additional step needed.
  • Run  /opt/dynatrace/oneagent/agent/uninstall.sh script on each Node, otherwise the migration fails.
    See documentation
