Is possible integrate dynatrace with movidesk?
and if it is possible exist any documentation about?
Hi @natanael_mendes ,
As far as I know, no documentation exists about integration of Dynatrace with Movidesk. To better answer your question, could you describe what information you’re trying to get from Movidesk and what it does? In addition, any information provided on what you’re trying to do by integrating it with Dynatrace would help too.
Cheers,
Taylor Sanchez
Thanks for your answer Taylor. Movidesk is a itsm tool for open tickets
Thanks for your Answer Danne, gon be helpful
