MQ, Solace appliance Infra Monitoring
Is there a way to monitor Infra metrics like CPU, Disk etc for MQ, Solace appliances using Dynatrace?
Dynatrace has an IBM MQ plugin/Extension you can use. also here is a link to the Built in metrics that we alert on:  Built-in classic metrics — Dynatrace Docs
here is a link to the MQs: Message queues — Dynatrace Docs
In terms of Solace, I dont see it as a supported technology but Perform is right around the corner, it could possibly be announced as supported in the future. Otherwise you can always toss in a RFE. Technology support — Dynatrace Docs
