Solace queue monitoring with Dynatrace
Is there a way to capture the age of the oldest message in the Solace queue via Dynatrace monitoring? I know we have a matric: Oldest message age for getting this in IBM MQ, but couldn’t find anything similar for Solace MQ. Any pointers are much appreciated.
Hi @Rinu
Have you tried monitoring the Solace MQ using Syslog? Then you can pull metrics from syslog into DT. Another thing is whether you have an API in Solace MQ after which you can pull the relevant metrics and send to Dynatrace?
Radek
