Hello Everyone:
We have the SSL certificate extension installed. Is there a way to perform a auto-discovery of all the certificates installed in our environment?.
Regards.
Hello Everyone:
Regards.
I think you need to have a OneAgent running on the host to have the certificate auto discovered or you would need to use the ActiveGate domain based discovery
p_devulapalli is correct. Certificate auto-discovery requires the SSL Certificate Extension to be enabled locally on OneAgent monitored hosts. The extension uses data collected by the OneAgent to help identify certificates on the host. We recommend deploying the extension using a limited deployment (filter on a management zone, tag, etc) to first to test the extension before deploying it environment wide.
Would Infrastructure monidoing mode be sufficient to perform Certificate auto-discovery on the monitored hosts with OneAgent. Or is full-stack monitoring needed?
@RTT You should be able to monitor certificates in “Infrastructure Only” mode
