Hello Team,
We do run Chaos engineering tests on the applications. The applications are currently publishing the metrics to Dynatrace. We want to generate custom events each time when Chaos experiments are run on the target application / host. So that we know Chaos experiments were run on the specific target and hence we know the reason for variation in the specific application metrics (which were impacted through chaos tests).
The Document: Events API v1 - POST an event — Dynatrace Docs Describes type of events supported by Dynatrace.
We want to differentiate the chaos experiment events at Dynatrace using specific event type name (example chaos-experiment).
- I need your suggestion on selecting the type of events to choose in the above mentioned scenario. My opinion is that, “CUSTOM_ANNOTATION” and “CUSTOM_INFO” events might suite well in our case.
- Also, I see “GET” and “POST” APIs supported for Events. But, in case of running Chaos experiments we may plan the test completion in advance but, we may have to remediate the chaos experiment earlier than planned end time as well. Hence, on sending Chaos experiment as an Event in Dynatrace while starting the Chaos experiment, we can set approximate endtime of experiment as event endtime. But, how to update the existing event in case if the Chaos experiment was to be remediated before the earlier estimated end time? We need to update the existing event.
Dinesh
