Network interfaces on ActiveGate
when you install a environment activeGate, can all network interfaces be used for agent connections, or should one be picked and configured,
KR Henk
As shown in the Agent Config file will show if agent traffic is enabeled,
Host name with domain, host name without domain and all ip numbers.
Quick question, are you asking if multiple ports can be used for AG to OneAgent communication? If so, then you can only use one port which defaults to 9999 but can be configured by changing the appropriate line in the config.properties file. More information can be found here: Supported connectivity schemes for ActiveGates — Dynatrace Docs
