We need to know on which port agent is connecting to security gateway? We will two gateways so we think there also will be communication between those two servers. Question is same: on which port?
We are using Dynatrace PaaS
OneAgents will send data to the Security Gateway over port 9999:
https://help.dynatrace.com/data-security/security-…
I don’t believe the gateways talk to each other, I expect the server keeps track of those.
James
