Has anyone encountered issues when attempting to set up a new AWS Connection method using the “No Active Gateway” option through a CloudFormation template?
Our deployment is failing at the following stage, and we’re trying to determine the root cause.
We’re getting into failed at following stage.
Resource: DynatraceLogIngestStackSet
Status: CREATE_FAILED
Error Message:
Resource handler returned message: “Resource of type 'Stack set operation [094d7702-3770] was unexpectedly stopped or failed. status reason(s): [The following resource(s) failed to create: [DynatraceFirehoseBackupS3Bucket, DynatraceFirehoseLogGroup]. Delete requested by user.]” (RequestToken: 6fa7d3b3-d0f2, HandlerErrorCode: NotStabilized)
Failed Resources:
- DynatraceFirehoseBackupS3Bucket
- DynatraceFirehoseLogGroup
