New container needs restart contained process to enable oneagent monitoring
It seems that a new (Docker) container within a cluster needs a restart to enable oneAgent to inject.
(it is dynamically linked (-; so no worries there)
An explanation is that the Go process is started before the OneAgent.
Does anybody have a remedy for this?
In my situation the OneAgent is installed on the OS,
KR Henk
This is just a node exporter for Prometheus. Do you really need to instrument it?
Hi Julius,
Short answer is no, on most instances this is turned off (-; but I am puzzled about the why, I was assuming that processes within new containers will be automatically monitored, when the Agent is installed. But in this scenario it looks like the exporter is started before the agent initialization?
Thanks for your reply,
KR Henk
KR Henk
