In the documentation I read that deploying a oneagent-docker container needs:
- There’s a startup dependency between the container in which OneAgent is deployed and application containers to be instrumented (i.e., which have deep process monitoring enabled). The OneAgent container must be started and the oneagenthelper process must be running prior to the application container being launched so that the application can be properly instrumented.
Does this also apply when you install the OneAgent on the OS? Or in other words can the oneagenthelper be used as a Activegate for docker?
KR Henk
