With 1.242, I have started seeing the problem indicator in the top right as the following:
Does the exclamation point have any meaning?
I would like to hear about that also as I am sure some execs will ask, but we havenât been upgraded yet. Wonder why not in the release notes? Dynatrace SaaS release notes version 1.242 | Dynatrace Docs
Unfortunately, UI changes rarely make their way into the release notes. There are tons of UI changes in 1.242, mostly configuration moved into other places. At least what I have noticed.
To best of my knowledge its more towards reading accessibility placing icons and doesnât have additional meaning, however should had been part of release notes.
They should put more in release notes as then people miss things.
Dynatrace!!! please provide an explanation of this new icon. Iâm getting questions from my users what this new icon indicates. If it doesnât provide an informational value then why was it even added, itâs just taking up more screen space and making the number smaller.
Sorry for the confusion, I was not aware that this change was not accompanied with a release note entry, I will reach out to the responsible team and give them feedback.
Now to the change, and I am pretty sure that the change will be received in a positive way.
First of all: We did not change the behaviour and semantic of the Davis problem indicator on top at all, we just added an icon to distinguish the Davis problem indicator from the upcoming Davis security vulnerabilities.
As we will start to show Security vulnerability indicator number on top as well, we had to come up with an icon to distinguish both indicators.
See below the upcoming Security indicator alongside the Davis Problem indicator:
I hope that explains the reasons for adding an icon on top and I am really sorry that we missed the icon change in our release notes.
Best greetings,
Wolfgang
Iâm all for improvements but I wonder what customer input went into this decision. My operations team puts the Dynatrace Problems page on a large screen for monitoring. Theyâve had issue already regarding the visibility of the problem count from a distance, this actually just makes things worse.
The icon provides no significant value, especially to people not paying for the security module. What percentage of your customers have both the Davis and Security module because this may only be helping a small percentage of your customers and impacting the larger percentage.
Whatâs probably the second most important metric Dynatrace could provide, second to knowing a Problem exists? Likely, the number of problems that my monitored environment is currently experiencing, yet that metric is actually a smaller font than the DatePicker text.
Thank you for the suggestion, although in that view the number can be massive, we then lose the details of the problems. If we had the ability to re-create the problems page in a dashboard with all the text attributes we would do that. Although, Iâd hope one day to re-create what @dannemca made (amazing work).
I do agree, the problem number on the top right never was ideal but itâs all we had. From one screen we need to see the problem details and the total count. Other things as well, but wonât get into that here. The best solution at the moment is the Problems page with the static DT header.
Any chance you can add the icon but not shrink the number? There is a lot of dead space between the search bar and problem count. Also, the responsive design could remove the icon maybe if resolution is below 770 pixels wide, which is when the Datetime Picker compresses.
I got it now, you are speaking purely about the problem feed and not about all the other pages right?
I will check if we can increase the indicator text a bit more.
Another suggestion from my side would be to also show the total number of open problems in the problem header? What do you think. Would that help your ops team? As the header is in large letters anyway this would render the number much more readable.
@wolfgang_beer thanks for suggesting solutions. If I disagree, doesnât mean Iâm not open for deeper discussion.
The initial discussion in general is about the Problem count on the Static Header. The moment the icon was added I received communications from my top end-users voicing the same concern that the number is smaller and the room is being consumed by an icon that doesnât really provide any meaningful value. They commented that the area is always RED (not like it changes RAG) so why not put Security problem counts into a blue or purple background and leave Problems in red and large. If itâs for accessibility, then use the ALT tags and a background color with higher contrast.
The conversation then spawned a secondary issue, that of the Operations Team.
Correct, the âproblems feedâ page is what our Operations team keeps up on a massive monitor 24/7 and then we display on 55" monitors around the building. For them itâs all about this page because itâs the only option they have to display Problem details.
Suggestion: âAnother suggestion from my side would be to also show the total number of open problems in the problem header?â
Response: Unfortunately I think that now puts the problem count on the screen too many times. That would be the 3rd presentation of the number. 1) Top right header, 2) between the bar chart and the problem details table, 3) in the problems header. It would be best to work with what we already have instead of adding a 3rd.
Suggestion: Between the bar chart and problem details table, could you add a few âProblem Statsâ horizontally and with maybe a slightly larger text. Say itâs 4 responsive design boxes. 1) Total Problems reported in the given timeline and filters 2) Total problems OPEN at the current moment 3) Total HOST Entity Problems Open (or other useful metric) 4) Total Application Entity Problems Open (or other useful metric). This would use existing landlocked white space on the page so it provides benefit without impacting anything else.
Suggestion2: Enlarge the font of the coutn between the bar chart and problem details but just add the text of âOpen Problems ####â next to it. e.g. â14 Problems (12 Open)â
Ok, I had a talk with the team and we will try to increase the size of the indicator number again.
Thanks for all your input.
Wolfgang
