Nice to know about entity selectors (and tagging)
You can use the entity selector on the  Relation target entity!
As an example, suppose you have multiple namespaces in Azure and you have the same name for a service bus queue in these namespaces.
You need to tag these queue’s using below entity selector.
type(azure_service_bus_queue),
toRelationships.isAzrServiceBusNamespaceOfQueue(type(AZURE_SERVICE_BUS_NAMESPACE),
entityName(“namespace”))
It looks like a complex query but if you read,
select this type, with this relation (but select only these target entities)
@henridb : thanks for sharing!
KR Henk
Thanks for sharing!
fromRelationships and toRelationships are great, that’s for sure.
For those that want to know where to get all possibilities, just check with Monitored entities API - GET entity type — Dynatrace Docs
:thankyou:for sharing this :wink:
@henk_stobbe Thanks for sharing this… looks intresting..
Sujit
