I would like to add some batch jobs to my app engine application and to verify if it works properly I must check logs of the application. Is there any way to download logs from app deployed on a cluster?
Best Regards,
Paweł
Best Regards,
Paweł
are your batch jobs running within AppFunctions? If so, you can query the logs within your environment. Please have a look at this page for more information: Monitor Dynatrace apps | Dynatrace Developer
best,
Sini
