Node Metadata in Webhook Payload
what attributes will provide Node Metadata to be used in Webhook PUSH notificaiton ?
Eg : IP address
Mac address
Hostname
@psudarsa I assume you might be referring to webhook notifications that are part of the Integration/Problem notifications ?
Here are the available placeholders , but not sure you would be able to include IP address or MAC address as node metadata unless they are part of the Problem details
You might have more flexibility if you are using workflows
Hi @psudarsa
To extract node metadata (IP, hostname, etc.) in a webhook payload:
Use {ProblemDetailsJSONv2} as the payload body it contains the full entity graph.
Parse the evidenceDetails and impactedEntities arrays in your receiving system to extract node-specific properties.
MAC address is generally not exposed as a Kubernetes node property. If you need it, consider pushing it as a custom tag or annotation on the node, which Dynatrace will then ingest and make available via {Tags} or entity properties.
Sujit
Adding to the answers above: if you can move to Workflows, you don’t need to parse ProblemDetailsJSONv2 on the receiving side. Add an Execute DQL Query task before your HTTP Request task, for example something like:
fetch dt.entity.host
| filter in(id, {{ event()["affected_entity_ids"] }})
| fields entity.name, ipAddress, osType
Then reference the query result in your webhook body. That gives you hostname and IP directly in the payload. As mentioned above, MAC address usually needs to come in via a tag or custom property.
