With step1 and step2 together result is that only one gitlab namspace will be monitored.
If you need more namespaces you should repeate the step2 or change the condition operator from equals to eg. contains. (eg. you can implement a naming convention for namespaces which require deep monitoring).
am trying your suggested solution step by step , starting with the step number 1 applying dont monitor namespace rules and wait for awhile but nothing happened, any idea?
If you use cloudNativeFullStack mode licences will not dercerase becasue the licensing worker node memory base (It does not matter which or how many namespaces are monitored. I you use applicationonly monitoring mode licences depend on the instrumneted pod memory limits. If you use my solution you should not see any services in the unmonitored namespaces.
