I would like to know what risks and benefits there are for turning on the following OneAgent Java features. For each one, what exactly do I get that’s new when turned on? I tried looking for documentation on these features but couldn’t find much.
Those flags enable support for instrumenting the particular libraries in your Java applications. If you use any of the features in your application, you have to enable the flags. Otherwise, traces will be incomplete.
All of the features are already in the product for quite a while and there is no risk of enabling them.
Do you know if some of those OneAgent features such as Java Spring Integration and Java/Scala Akka Remoting come with more than tracing? Like do any of these also come with deep code insights and/or new metrics?
You might have some extended visibility there, too when it comes to method hotspots. Reactive applications are good example - without the tracing support, you won’t be able to see method hotspots for all stacktrace samples when requests are processed in different threads and Dynatrace is not tracking them.
Enabling tracing support is crucial. It’s perfectly safe to enable them.
you need to also look at each feature and release notes to get as much details as possible. Dynatrace does not always do a great job of documenting it completely
