Oneagent Business event extraction when on Azure Function
Hello Community members,
are you aware if Oneagent Business event extraction can also work when Dt is deployed on an Azure Function?
Regards
Hi @y_buccellato
Yes, it’s possible to capture business events (BizEvents) from your Azure Function. If you’re able to deploy the OneAgent to the Azure Function, it will automatically capture the payload as part of the trace. Alternatively, if deploying OneAgent is not feasible due to architectural constraints, you can implement a call within the function to send the same payload directly to the BizEvents API. This alternative method is effective and ensures that, regardless of the deployment limitations, you can successfully extract BizEvents from your Azure Function by capturing the trace through one of these approaches.
@JoseRomero  can you explain how this can be done from your previous reply? “you can implement a call within the function to send the same payload directly to the BizEvents API”
In my application we have 3 azure function as part of process and each has same call “Invoke” but different payload . I would like to set bizevent for all those 3 invoke call
