OneAgent Queue Inspection
Hello
We’ve observed that when the Host Unit license capacity is reached, newly installed OneAgents appear to be queued. When monitoring is deactivated for some active hosts, licenses become available, and the queued OneAgents are picked up and displayed in the UI.
Is it possible to inspect this queue and determine the number of new OneAgents currently waiting due to the Host Unit license limit?
Hi @Gazerbeam
Regarding the raised points, PFA for detailed info:
For HU Consumption:
The applicable solution:
  • keep sufficient HU buffer to ensure all required servers are monitored as intended and there is no suspension or idle state.
Hoping that helps.
KR,
Peter
