Dear All,
Please correct my understanding about the unlicensed filter.
Will this show the unmonitored hosts due to the reached quota or something else because the unmonitored filter is for the same? If this is for the same, then I can confirm that it is not filtering out those hosts.
Babar
Hi @Babar_Qayyum ,
I have the same question, and based on what is mentioned in below URL, it should be
currently, I’m getting all hosts that are not monitored due to reaching quota from OneAgent Health
Hello @Mohamed_Hamdy
I was checking the unlicensed filter in the OneAgent deployment status. Did you check on the same?
Babar
Hello @Babar_Qayyum , yes, I have been checking this since it was released but I can’t find any data, maybe it’s related to DPS but not quite sure
