Good afternoon community,
struggling with OpenPipeline as I get confused by different settings in Dynatrace.
The original situation is the following:
- I “log forward” logs from Azure to DT via Dynatrace Azure Native Service - so far so good.
- When data come in Dynatrace there is a processing rule (created by DT): [Built-in] cloud:azure:common
- I create a bucket with a specific matcher to just pick some lines out of all the log - up until here everything is Vanilla
- Now: I want to create a pipeline that parse exactly the same lines to extract some additional field.
- here is my doubt: during the processing step set up, should I consider the log lines as I can query it in Notebook (with step 2 applied) or Should I consider only the “content” field of each line before step 2 is applied?
Already existing processing rule on logs gets me always confused with processing step in pipeline…
Thank you to whomever will clarify this,
regards
