ANLTH
February 11, 2025, 1:19pm
1
In an Open Pipeline, I have created a field “Synctime”, when extracting a Metric I have added the the new field as a Custom dimension, but it looks like the field is not added to the Metric as dimension?
Anyone who has experienced and solved the same?
Anne-Lis
Hi @ANLTH ,
When you run the DQL query in a notebook, do you see the data split(summarized) by the dimension you want there?
I was able to add a new field and then use it as a metric dimension in my own environment. Would you be able to share your configurations?
Without see the config, here is a couple of ideas for what could go wrong:
field name misspelled on metric extraction
matching condition for adding new field is excluding intended logs
matching condition for the pipeline is excluding the intended logs
ANLTH
February 13, 2025, 8:05am
4
Hi
@Fin_Ubels I had attached a file showing the configuration.
@RohitBisht No I was not able to see the field in the split.
Today though - the Synctime is there when displaying the Metric (in Metric app) and I am able to split by/filter on the field.
I have not made any changes - I must belive that someone @Dynatrace has - anyway I am happe I got my solution.
