Open Pipeline - Metric extraction
I am using Open Pipeline to process log ingest.
I need to extract a Metric for Synchronization time - which is a field in my log record.
How do I specify that the metric shall be based on this field?
I know I can add the field as a dimension, but that does not give me sufficient possiblilites when working with the metric.
Can you provide a sample log line and I’ll take a look?
Does this help? Parse log lines and extract a metric — Dynatrace Docs
