I’m new in the community and in the use of Dynatrace.
There is someway to extract specific fields in a custom trace log.
I associate the custom log to the process but I don’t find a way to extract and create a custom field.
For example if I have a logfile with these line pattern:
25/01/2021 ORD1234 OK
Is there some way to identify the ORD1234 as NrOrder and OK as Result fields to use in the search text for post processing?
Thank’s a lot for helping me
Hello @dcappare
If you are looking for the log custom attributes. Please have a look at the below link:
Babar
Hi Babar,
thank for your reply. I have some doubt because in this article it seems that the custom metric is to built only for json log but i don’ t understand if this is possible for log4Net , log4j or custom log defining some rule or regular expr to extract a specific field as a metric.
thanks a lot for your support
Hi dcappare,
You are correct, you can create custom metrics from API ingested logs in JSON at the moment.
Extracting specific fields from plaintext logs will be available soon!
Best regards,
Hans
“Extracting specific fields from plaintext logs will be available soon!”
Any information on which release it is planned? Looking forward to it too.
Most precise information will definitely be in the release notes, but the team will post here too when a release time is certain-
@HansLougas : Do you have an ETA for this feature ?
Hi, I am eager to share a specific ETA, but currently asking to please hold.
I will keep this thread posted as soon as we have ETA.
Here are some promises and an outlook:
Thanks for posting this here also Mathias!
I recommend watching through the whole Observability Clinic session, but if you’re curious about extracting fields from log record, see from 53:26.
Hi all,
I’m happy to share that Log Processing has been released in Preview in Dynatrace 1.242.
Please see this feedback channel for more details.
Hi Babar
log.source= “/opt/jboss/var/main.log” AND (content=“error” OR content=“ERROR” OR content=“warning” OR content=“Warning”) - this is our log source. we want to get alert only if first line of content starts with error.
With the above setting, it is generating alerts when there is word “ERROR” in the entire log file
