Problem Statement
I’m monitoring a Windows Server 2025 host with OpenTelemetry Collector Contrib (v0.150.1) and sending metrics to Dynatrace via OTLP. Most metrics are flowing correctly (CPU, memory, disk, filesystem), but two key issues:
Health column remains empty (shows -) in the Hosts view
Process Count and Processes Created metrics are not visible in Dynatrace despite being configured and exported
Configuration
- Platform: Windows Server 2025 Standard
- Collector: otelcontribcol v0.150.1 amd64
- Backend: Dynatrace SaaS ({ENVIRONMENT_ID}.live.dynatrace.com/api/v2/otlp)
- Protocol: OTLP HTTP
Receivers
- hostmetrics/10s — CPU utilization, memory utilization, network, processes count/created, load 1m
- hostmetrics/5m — CPU time, memory usage, disk I/O, filesystem, paging, per-process metrics, load 5m
- hostmetrics/1h — Memory limit, CPU logical/physical counts, uptime, load 15m, processes
- windowsperfcounters/30s — Processor, Memory, Process (7 instances), PhysicalDisk counters
- windows_event_log — System channel
Metrics Being Collected & Exported
system.cpu.utilization (10s)
system.memory.utilization (10s)
system.processes.count (10s, 5m, 1h)
system.processes.created (10s, 5m, 1h)
system.uptime (1h)
system.cpu.load_average.1m/5m/15m (across intervals)
system.memory.limit (1h)
system.cpu.logical.count & system.cpu.physical.count (1h)
All Windows perfcounter metrics (transformed to windows.* namespace)
All system resource attributes (host.name, host.arch, os.type, os.description, os.version, os.build.id, etc.)
Verified: Metrics are reaching Dynatrace (visible in (configured in 3 separate scraper intervals) 2.
Removed cardinality filtering to ensure all metrics pass through 3.
Verified both system.processes.count and system.processes.created metrics are in the config 4.
Verified resource detection is enabled with 13 attributes 5.
Confirmed sending_queue and batch processors are configured 6.
Checked that metrics have correct data types and values 7.
Ensured all metrics flow without errors in collector log with 13 attributes 4.
Confirmed sending_queue and batch processors are configured 5.
Checked that metrics have correct data types and values 6.
Current State
- Collector runs without errors
- All metrics export successfully to Dynatrace
- Mey are process count metrics and health status not appearing in Dynatrace?**
- For Process metrics: system.processes.count and system.processes.created are configured, exported, and flow without errors. Why don’t they appear in Dynatrace UI?
- Missing a required attribute or dimension?
- Wrong metric naming convention?
- Requires a different field/resource mapping?
- For Health Status: What does Dynatrace need to calculate and display health status for a Windows host?
- Is there a specific health status metric (system.status, host.health, etc.)?
- Do I need additional metrics beyond what’s currently collected?
- Is there a minimum frequency or volume requirement for health calculation?
- Should I be exporting collector internal telemetry (otelcol_* metrics)?
- Is there a Dynatrace-specific configuration or entity type required?
Configuration Reference
Processors pipeline:
[batch] → [filter (idle CPU)] → [transform (cardinality cleanup)] →
[cumulativetodelta] → [metricstransform (perfcounter renaming)] →
[resourcedetection] → [otlp_http/dynatrace]
Exporter:
- Endpoint: https://{environmentid}.live.dynatrace.com/api/v2/otlp
- Sending queue: min_size=3000, max_size=3000, flush=60s
Environment
- Dynatrace Version: Latest SaaS ({ENVIRONMENT_ID}.live.dynatrace.com)
- OpenTelemetry Collector: v0.150.1 (Contrib, Windows amd64)
- Collection Running Time: ~30+ minutes (continuous)
Complete Configuration File
otel_dynatrace_only.yaml
<span class="">extensions:</span>
<span class="">health_check:</span>
<span class="">endpoint:</span> <span class="">0.0</span><span class="">.0</span><span class="">.0</span><span class="">:13133</span>
<span class="">receivers:</span>
<span class="">otlp:</span>
<span class="">protocols:</span>
<span class="">grpc:</span>
<span class="">endpoint:</span> <span class="">0.0</span><span class="">.0</span><span class="">.0</span><span class="">:4317</span>
<span class="">http:</span>
<span class="">endpoint:</span> <span class="">0.0</span><span class="">.0</span><span class="">.0</span><span class="">:4318</span>
<span class="">hostmetrics/10s:</span>
<span class="">collection_interval:</span> <span class="">10s</span>
<span class="">scrapers:</span>
<span class="">cpu:</span>
<span class="">metrics:</span>
<span class="">system.cpu.utilization:</span>
<span class="">enabled:</span> <span class="">true</span>
<span class="">system.cpu.time:</span>
<span class="">enabled:</span> <span class="">false</span>
<span class="">memory:</span>
<span class="">system.memory.utilization:</span>
<span class="">system.memory.usage:</span>
<span class="">network:</span>
<span class="">system.network.io:</span>
<span class="">system.network.packets:</span>
<span class="">system.network.errors:</span>
<span class="">system.network.dropped:</span>
<span class="">system.network.connections:</span>
<span class="">processes:</span>
<span class="">system.processes.count:</span>
<span class="">system.processes.created:</span>
<span class="">load:</span>
<span class="">system.cpu.load_average.1m:</span>
<span class="">hostmetrics/5m:</span>
<span class="">collection_interval:</span> <span class="">5m</span>
<span class="">disk:</span>
<span class="">system.disk.io:</span>
<span class="">system.disk.operations:</span>
<span class="">system.disk.io_time:</span>
<span class="">system.disk.operation_time:</span>
<span class="">filesystem:</span>
<span class="">include_devices:</span>
<span class="">match_type:</span> <span class="">strict</span>
<span class="">devices:</span> [<span class="">"C:"</span>, <span class="">"D:"</span>]
<span class="">system.filesystem.utilization:</span>
<span class="">system.filesystem.inodes.usage:</span>
<span class="">paging:</span>
<span class="">system.paging.usage:</span>
<span class="">system.paging.operations:</span>
<span class="">process:</span>
<span class="">mute_process_all_errors:</span> <span class="">true</span>
<span class="">process.cpu.utilization:</span>
<span class="">process.cpu.time:</span>
<span class="">process.memory.usage:</span>
<span class="">process.memory.virtual:</span>
<span class="">process.disk.io:</span>
<span class="">system.cpu.load_average.5m:</span>
<span class="">hostmetrics/1h:</span>
<span class="">collection_interval:</span> <span class="">1h</span>
<span class="">system.memory.limit:</span>
<span class="">system.cpu.logical.count:</span>
<span class="">system.cpu.physical.count:</span>
<span class="">system:</span>
<span class="">system.uptime:</span>
<span class="">system.cpu.load_average.15m:</span>
<span class="">windowsperfcounters:</span>
<span class="">collection_interval:</span> <span class="">30s</span>
<span class="">perfcounters:</span>
<span class="">-</span> <span class="">object:</span> <span class="">"Processor"</span>
<span class="">instances:</span> [<span class="">"_Total"</span>]
<span class="">counters:</span>
<span class="">-</span> <span class="">name:</span> <span class="">"% Processor Time"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"% Privileged Time"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Interrupts/sec"</span>
<span class="">-</span> <span class="">object:</span> <span class="">"Memory"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Available MBytes"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"% Committed Bytes In Use"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Cache Bytes"</span>
<span class="">-</span> <span class="">object:</span> <span class="">"Process"</span>
<span class="">-</span> <span class="">"svchost"</span>
<span class="">-</span> <span class="">"lsass"</span>
<span class="">-</span> <span class="">"csrss"</span>
<span class="">-</span> <span class="">"services"</span>
<span class="">-</span> <span class="">"sqlservr"</span>
<span class="">-</span> <span class="">"w3wp"</span>
<span class="">-</span> <span class="">"otelcol-contrib"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Working Set - Private"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Private Bytes"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Thread Count"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Handle Count"</span>
<span class="">-</span> <span class="">object:</span> <span class="">"PhysicalDisk"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"% Disk Time"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Disk Bytes/sec"</span>
<span class="">-</span> <span class="">name:</span> <span class="">"Avg. Disk Queue Length"</span>
<span class="">windows_event_log:</span>
<span class="">channel:</span> <span class="">System</span>
<span class="">start_at:</span> <span class="">end</span>
<span class="">processors:</span>
<span class="">batch:</span>
<span class="">timeout:</span> <span class="">10s</span>
<span class="">send_batch_size:</span> <span class="">1024</span>
<span class="">filter:</span>
<span class="">datapoint:</span>
<span class="">-</span> <span class="">metric.name</span> <span class="">==</span> <span class="">"system.cpu.utilization"</span> <span class="">and</span> <span class="">attributes["state"]</span> <span class="">==</span> <span class="">"idle"</span>
<span class="">transform:</span>
<span class="">error_mode:</span> <span class="">ignore</span>
<span class="">metric_statements:</span>
<span class="">-</span> <span class="">context:</span> <span class="">datapoint</span>
<span class="">statements:</span>
<span class="">-</span> <span class="">delete_key(resource.attributes,</span> <span class="">"process.cgroup"</span><span class="">)</span> <span class="">where</span> <span class="">IsMatch(metric.name,</span> <span class="">"^process\\..*"</span><span class="">)</span>
<span class="">-</span> <span class="">delete_key(resource.attributes,</span> <span class="">"process.command"</span><span class="">)</span> <span class="">where</span> <span class="">IsMatch(metric.name,</span> <span class="">"^process\\..*"</span><span class="">)</span>
<span class="">-</span> <span class="">delete_key(resource.attributes,</span> <span class="">"process.executable.path"</span><span class="">)</span> <span class="">where</span> <span class="">IsMatch(metric.name,</span> <span class="">"^process\\..*"</span><span class="">)</span>
<span class="">-</span> <span class="">delete_key(resource.attributes,</span> <span class="">"process.owner"</span><span class="">)</span> <span class="">where</span> <span class="">IsMatch(metric.name,</span> <span class="">"^process\\..*"</span><span class="">)</span>
<span class="">-</span> <span class="">delete_key(resource.attributes,</span> <span class="">"process.parent_pid"</span><span class="">)</span> <span class="">where</span> <span class="">IsMatch(metric.name,</span> <span class="">"^process\\..*"</span><span class="">)</span>
<span class="">-</span> <span class="">delete_key(resource.attributes,</span> <span class="">"process.command_args"</span><span class="">)</span> <span class="">where</span> <span class="">IsMatch(metric.name,</span> <span class="">"^process\\..*"</span><span class="">)</span>
<span class="">-</span> <span class="">delete_key(datapoint.attributes,</span> <span class="">"device"</span><span class="">)</span> <span class="">where</span> <span class="">datapoint.attributes["device"]</span> <span class="">==</span> <span class="">""</span>
<span class="">filter/delete-metrics:</span>
<span class="">metric_conditions:</span>
<span class="">-</span> <span class="">datapoint.attributes["low-memory-process"]</span> <span class="">!=</span> <span class="">nil</span>
<span class="">cumulativetodelta:</span>
<span class="">max_staleness:</span> <span class="">25h</span>
<span class="">metricstransform:</span>
<span class="">transforms:</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Processor\(_Total\)\\\\% Processor Time$'</span>
<span class="">action:</span> <span class="">update</span>
<span class="">new_name:</span> <span class="">windows.processor.time</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Processor\(_Total\)\\\\% Privileged Time$'</span>
<span class="">new_name:</span> <span class="">windows.processor.privileged_time</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Processor\(_Total\)\\\\Interrupts/sec$'</span>
<span class="">new_name:</span> <span class="">windows.processor.interrupts</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Memory\\\\Available MBytes$'</span>
<span class="">new_name:</span> <span class="">windows.memory.available</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Memory\\\\% Committed Bytes In Use$'</span>
<span class="">new_name:</span> <span class="">windows.memory.committed_usage</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Memory\\\\Cache Bytes$'</span>
<span class="">new_name:</span> <span class="">windows.memory.cache</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Process\(.*\)\\\\% Processor Time$'</span>
<span class="">new_name:</span> <span class="">windows.process.cpu_time</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Process\(.*\)\\\\% Privileged Time$'</span>
<span class="">new_name:</span> <span class="">windows.process.privileged_time</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Process\(.*\)\\\\Working Set - Private$'</span>
<span class="">new_name:</span> <span class="">windows.process.working_set_private</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Process\(.*\)\\\\Private Bytes$'</span>
<span class="">new_name:</span> <span class="">windows.process.private_bytes</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Process\(.*\)\\\\Thread Count$'</span>
<span class="">new_name:</span> <span class="">windows.process.threads</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\Process\(.*\)\\\\Handle Count$'</span>
<span class="">new_name:</span> <span class="">windows.process.handles</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\PhysicalDisk\(_Total\)\\\\% Disk Time$'</span>
<span class="">new_name:</span> <span class="">windows.disk.time</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\PhysicalDisk\(_Total\)\\\\Disk Bytes/sec$'</span>
<span class="">new_name:</span> <span class="">windows.disk.throughput</span>
<span class="">-</span> <span class="">include:</span> <span class="">'^\\\\PhysicalDisk\(_Total\)\\\\Avg\. Disk Queue Length$'</span>
<span class="">new_name:</span> <span class="">windows.disk.queue_length</span>
<span class="">resourcedetection:</span>
<span class="">detectors:</span> [<span class="">"system"</span>]
<span class="">resource_attributes:</span>
<span class="">host.arch:</span>
<span class="">host.id:</span>
<span class="">host.name:</span>
<span class="">host.ip:</span>
<span class="">host.interface:</span>
<span class="">host.mac:</span>
<span class="">host.cpu.model.name:</span>
<span class="">os.type:</span>
<span class="">os.description:</span>
<span class="">os.name:</span>
<span class="">os.version:</span>
<span class="">os.build.id:</span>
<span class="">exporters:</span>
<span class="">otlp_http/dynatrace:</span>
<span class="">endpoint:</span> <span class="">"https://{environmentid}.live.dynatrace.com/api/v2/otlp"</span>
<span class="">headers:</span>
<span class="">Authorization:</span> <span class="">"Api-Token {DYNATRACE_API_TOKEN}"</span>
<span class="">sending_queue:</span>
<span class="">min_size:</span> <span class="">3000</span>
<span class="">max_size:</span> <span class="">3000</span>
<span class="">flush_timeout:</span> <span class="">60s</span>
<span class="">service:</span>
<span class="">extensions:</span> [<span class="">health_check</span>]
<span class="">pipelines:</span>
<span class="">receivers:</span> [<span class="">hostmetrics/10s</span>, <span class="">hostmetrics/5m</span>, <span class="">hostmetrics/1h</span>, <span class="">windowsperfcounters</span>]
<span class="">processors:</span> [<span class="">batch</span>, <span class="">filter</span>, <span class="">transform</span>, <span class="">filter/delete-metrics</span>, <span class="">cumulativetodelta</span>, <span class="">metricstransform</span>, <span class="">resourcedetection</span>]
<span class="">exporters:</span> [<span class="">otlp_http/dynatrace</span>]
<span class="">logs:</span>
<span class="">receivers:</span> [<span class="">windows_event_log</span>, <span class="">otlp</span>]
<span class="">processors:</span> [<span class="">batch</span>, <span class="">resourcedetection</span>]
Additional Context
The host metrics themselves are healthy and complete. The question is whether Dynatrace requires additional signals, different metric frequencies, or specific configuration to calculate overall host health status.
Any guidance appreciated! 🙏
