Use of OpenTelemetry Dashboard(https://www.dynatrace.com/hub/detail/opentelemetry-dashboards/)
I added the dashboard (https://www.dynatrace.com/hub/detail/opentelemetry-dashboards/) from your hub to my Dynatrace environment, to monitor my opentelemetry collector. But this dashboard is expecting metrics like otelcol_receiver_accepted_spans and what I am getting from the basic configuration that is given in the documentation is metrics like otelcol_receiver_accepted_spans.count. I have this “.count” on all metrics required by the dashboard and so the dashboard is empty. I tried everything to get those metrics in the correct format but I can’t make it work. Can you tell me what I’m doing wrong ?
I followed the documentation and I don’t have anything special in my configuration.
my config :
telemetry:        metrics:          level: detailed          readers:            - periodic:                interval: 60000                exporter:                  otlp:                    protocol: http/protobuf                    temporality_preference: delta                    endpoint: “${env:DT_ENDPOINT}/v1/metrics”                    headers:                      - name: Authorization                        value: “Api-Token ${env:DT_API_TOKEN}”
Thanks in advance for your help,
Eva
Sorry the dashboard I’m trying to use is : OpenTelemetry Collector self-monitoring — Dynatrace Docs
J’utilise l’image opentelemetry-collector-contrib:0.144.0, est-ce que le problème vient d’une incompatibilité avec l’image contrib ?
