HI colleagues, In my Spring Boot application, I’d like to use OpenTelemetry to send monitored data to Dynatrace. After collecting this data, I intend to create dashboards or set up alerts. How can I achieve this? Should I use OpenTelemetry metrics, or is there an alternative approach you would recommend? any link for references?
Once your data come to Dynatrace, thru the OTel integration, you should see the metrics in Dynatrace and use the Data Explorer to create your dashboard and then the Metric Events for Alerting, to get the problems generated for.
