Hi All,
We need to find oracle DB leak connection associate with which request/service?
Gauresh
Hi All,
Gauresh
Hi @gauresh_shinde ,
I have only experience with Weblogic + Oracle, I can not define which request / service associated with the leaked connection. I can define only the affected data source. It is provided by the Weblogic connection pool monitoring feature. There are connection pool monitoring features for the other technologies also, but I do not know those possibilities.
Best regards,
Mizső
This blog post has some details on how it works:
Beware that you have to have JMX configured in your Application Server. It really doesn’t depend on the database being used. You can then configure one of them for your use-case:
