Packet retransmission rate configuration for process
Dear All,
Is there a way to configure the packet retransmission rate for the individual processes?
Is there a way to exclude particular processes from the network traffic monitoring?
Babar
I would assume you could do this at a more granular level via the custom events for alerting.
Hi Babar,
did you find a solution for this?
Hello @rakan_khlailah
I could not exclude the process but I have created a custom event for alerting (retransmission based received) and given a higher value to avoid the alert.
Babar
