Parse JSON array
Hi all, is it possible in DQL to parse a JSON string that contains an array on the top level?
I can parse a top-level JSON object like
data record(value = "{\"hello\" : \"world\"}")<br>| parse value, "JSON:json"
But I fail to parse a top-level JSON array:
data record(value = "[{\"hello\" : \"world\"}]")<br>| parse value, "JSON:json"
Hi Stefan, you have to use JSON_ARRAY for that:
| parse value, "JSON_ARRAY:greeting"
| fields greeting
