Pods stuck in Terminating state after upgrade
If your CSI driver and OneAgent pods get stuck in Terminating state after upgrading from Dynatrace Operator version 0.9.0, you need to manually delete the pods that are stuck.
Run the command below.
Kubernetes
kubectl delete pod -n dynatrace --selector=app.kubernetes.io/component=csi-driver,app.kubernetes.io/name=dynatrace-operator,app.kubernetes.io/version=0.9.0 --force --grace-period=0
OpenShift
oc delete pod -n dynatrace --selector=app.kubernetes.io/component=csi-driver,app.kubernetes.io/name=dynatrace-operator,app.kubernetes.io/version=0.9.0 --force --grace-period=0
