PostgreSQL extension
Has anyone successfully configured the postgreSQL extension?
I’ve gone thru the documentation at the following links:
https://www.dynatrace.com/hub/detail/postgresdb-remote-monitoring/
Configuration properties and parameters of ActiveGate — Dynatrace Docs
I have activated the Extensions 1.0 and Extensions 2.0 taking as reference the following dynatrace community issue:
https://community.dynatrace.com/t5/Extensions/Failed-to-assign-monitoring-in-MSSQL-Extension/m-p/208676
My dynatrace active gate version is:
Name Version ActiveGate 1.297.7.20240820-171627
The active capabilities/modules are:
Modules
Extensions 1.0 (deprecated)
​Enabled
Extensions 2.0
​Enabled
Kubernetes
​Enabled
OneAgent routing
​Enabled
REST API
​Enabled
Yet every time I try to configure my PostgreSQL extension I get the following message:
Failed to assign monitoring configuration to ActiveGate. Reason: The monitoring configuration requires ActiveGate version 1.293.0 or later that supports data source sqlPostgres and belongs to group “default”
What am I missing?
Looks like is an ActiveGate configuration issue. Extension need to run in a ActiveGate group. You need to define that.
It can be done during ActiveGate installation or later.
Best regards
My suggestion.
Spin a new AG only with extension modules activated, and disable any other module. Configuration properties and parameters of ActiveGate — Dynatrace Docs
Assign the AG to a group “Extensions” as suggested by @AntonPineiro  and redeploy the extension in this new AG
Thank you all!
I’ve come to the understanding that limited options for Extensions 2.0 are available for Active gates in a containerised environment. I guess for now I’ve got nothing but to wait until the postgreSQL feature is released for K8s environment.
Thanks, MJ
