Hi Team,
I am integrating Problem Notifications into a Google espace webhook, but I am getting an http 400 error
“Invalid JSON payload received”
These are the steps I have taken:
Create space on google.
Create webhook integration in Google space.
Create the Problem Notifications integration in Dynatrace.
I paste the Webhook.
Then I give test notifications and I get error 400
Does anyone know what could be happening or what needs to be done for it to work? or failing that if it is not compatible.
It is the format of webhook.
error
Custom Integration test failed
Reason: Invalid HTTP status code
HTTP Response Code: 400 - Bad Request
HTTP Response Body:
{ “error”: { “code”: 400, “message”: “Invalid JSON payload received. Unknown name \“State\” at ‘message’: Cannot find field.\nInvalid JSON payload received. Unknown name \“ProblemID\” at ‘message’: Cannot find field.\nInvalid JSON payload received. Unknown name \“ProblemTitle\” at ‘message’: Cannot find field.”, “status”: “INVALID_ARGUMENT”, “details”: [ { “@type”: “type.googleapis.com/google.rpc.BadRequest”, “fieldViolations”: [ { “field”: “message”, “description”: “Invalid JSON payload received. Unknown name \“State\” at ‘message’: Cannot find field.” }, { “field”: “message”, “description”: “Invalid JSON payload received. Unknown name \“ProblemID\” at ‘message’: Cannot find field.” }, { “field”: “message”, “description”: “Invalid JSON payload received. Unknown name \“ProblemTitle\” at ‘message’: Cannot find field.” } ] } ] } }
All this in SAAS.
Greetings Dynatrace Lovers.
