Good afternoon everyone,
With the objective of monitoring a mobile application for iOS and Android, the procedure was carried out using the “Dynatrace Cordova plugin” according to the Dynatrace guide. However, during compilation, the following error is thrown: "A problem occurred configuring project ‘:capacitor-cordova-android-plugins’.
> Could not resolve all files for configuration ‘:capacitor-cordova-android-plugins:classpath’.
> Could not find org.jetbrains.kotlin:kotlin-gradle-plugin:1.7.1.
Searched in the following locations:
- https://dl.google.com/dl/android/maven2/org/jetbrains/kotlin/kotlin-gradle-plugin/1.7.1/kotlin-gradle-plugin-1.7.1.pom
- https://repo.maven.apache.org/maven2/org/jetbrains/kotlin/kotlin-gradle-".
Currently, the project has the following libraries:
Ionic project version: v5.4.16
Version of the Dynatrace Cordova package installed (latest): @dynatrace/cordova-plugin": “^2.291.1”.
Would appreciate your help.
