Problems setting up IBM MQ v2.0 extension
Hi I’m running into an issue with the new MQ extension version 3.3.1. I have 5 queue managers running on a single server. When I do a new configuration for each queue manager I am getting a green button OK for each, but when I go to the dashboard only one of the queue manager’s is showing up. Is there anyone who has run into the same issue, and where you able to resolve it?
Hi @david_petty ,
Most likely permissions but the logs will confirm.
There are some things you can check and the Dynatrace Hub Tile for the extension has a FAQ & Troubleshooting portion you can try. If after you’ve tried that, it still doesn’t work, you’ll have to open a Support ticket.
Diego
