Relationship Limit Error when enabling the IBM MQ V2 Extension [solution]
When enabling the IBM MQ V2 Extension users might run into a Relationship Limit Error.
This Error is only seen via the new host view layout and can appear once the extension is enabled in the hub even though there isn’t any configurations defined yet.
Solution:
Create a support ticket and request the Generic Relationships to be increased. You can Reference Support ticket: 239825 for more Dynatrace Support context.
If this V2 extension is needed in your environment and you cannot wait for DT Support to raise the limit, you can access the Host via the Classic view, but not via the new layout/view. You will have to remove the extension in order to use the new host view/layout.
Hope this helps!
Thank you Chad!
