Can anyone please let me know what does “process group low instance count” alerts mean?
Hi @raz,
It seems you have an active process group availability rule. If you need more processes to ensure the service level for the customers you can set up a process group availabilty rules. Eg. you have 4 processes which ones provide the same servcies but minimum 2 of them should be work to serve your clinets without any perfromance issues.
Process group availability monitoring and alerting | Dynatrace Docs
I hope it helps. Have a nice day.
Best regards,
Mizső
