Worker Process Monitoring
Hi all,
Is there an option in Dynatrace to set a threshold for the minimum number of worker processes running in a process group instance? If the threshold is not met, can it trigger the creation of a problem ticket?
Prashanth Reddy
Yes, you can enable Process group availability monitoring and alerting
Best regards
Thanks for your reply. I have enabled it, but now I’m looking set a threshold for the minimum number of worker processes running in a process group instance.
You can use below metric for this. Use it in metric events for alerting.
builtin:tech.generic.processCount
